straight pole light
straight pole light
hello
can anybody tell me how i can calculate the force to straight light pole after welding if the diameter of pole is 200mm and the power of piston
RE: straight pole light
i need to straight light pole after welding process because the pole after welding become a deflection ( banana effect )(no straight)then i need to determine the force to return the pole straight by hydraulic press .
the pole have curricular cross section with diameter 200mm and 5mm thickness and material is A36 steel. and length the pole is 12 m
The pole has a bunch of thermal stress and he wants to know how big his press needs to be to make the pole straight...
It's 12 mtrs long...it wont need much
B.E.
You are judged not by what you know, but by what you can do.
