Determine interfering dimension lines in drawing using NXOpen ?
Hello friends,
I am trying to determine all the interfering/ intersecting dimension lines in my drawing files using NXOpen and NX9.
Is there any way we can achieve this using code ?
Thank you in advance.
Amitabh
RE: Determine interfering dimension lines in drawing using NXOpen ?
Thank you Cowski for the pointer.
That sure helps. I will let you know if this solved my purpose.
Thank you once again.
Amitabh
