60% shear with -20F CVNs
I have a customer RFQ asking for 60-80% shear in CVN tests at -20F. Most of what we have available is in the range of 20-50% shear in the weld and HAZ, with some WPS having up to 100% in the HAZ only. Typically looking at GTAW with ER70S-6. Heat input is 25.5 kJ/in root and 46kJ/in fill/cap.
To get that much improvement I assume it will require a different wire altogether? I don't generally see shear values reported by manufacturers and have not run across a customer spec requiring shear minimums before.
RE: 60% shear with -20F CVNs
