Pressure Vessel alterations and safety
Ok I have attached a photo for everyone to look at and hopefully I can explain what it is I am asking. In the photo there is a pressure vessel that is used with sandblasting that comes certified from a manufacturer. Afterwards there is a flange or ring that is welded to the head pipe to allow a cone to be bolt to the pressure vessel for media storage, mind you this is done by a non code shop and never certified after the alteration.
What I am being told is because the cone is not under pressure this is considered to be safe and not required to be tested and still falls into the original testing and certifications. Yes there is usually no pressure inside the cone are unless the valve breaks or is worn, but even if there never is any pressure in the cone, there is pressure under the head pipe which is where the flange is welded to, which is also directly under the cone. My concern is the welding of the flange to the head pipe caused fatigue and stresses to the pressure vessel and now needs to be tested over and certified to be safe. I also feel that the alteration being done by a non code shop is another reason to not use the pressure vessel
The company did provide documents from when the pressure vessel was designed and tested to be safe, but they could not provide anything afterwards because nothing was submitted to the National Board about the alteration.
Does the explanation of there being no pressure inside the cone and is considered safe sound correct? To me and others this is absolutely crazy. It is like saying it will only effect the inside of the pressure vessel and not the outside.
RE: Pressure Vessel alterations and safety
