MOV types?/motor operated valve
what MOV means exactly, is the actuator type always electrical? or we can call the valve actuated with fluid power actuator MOV also?
RE: MOV types?/motor operated valve
A piston type actuator would normally be referred to as an XV.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
