Errors about degree of freedom 11
Hi friends, I'm new here and also as abaqus users. I try to learn about the software by following some tutorial from youtube. Included this tutorial https://www.youtube.com/watch?v=UCUdsn8bIwY about impact bullet, because i need to do my final project about bird strike.
I follow the tutorial precisely but this is what i've got:
errors:
Degree of freedom 11 and at least one of degrees of freedom 1 thru 6 must be active in the model for *dynamic temp-disp. Check the procedure and element types used in this model.
warnings:
Both the transition and melting temperatures are zero. Temperature dependencies are suppressed
The option *boundary,type=displacement has been used; check status file between steps for warnings on any jumps prescribed across the steps in displacement values of translational dof. For rotational dof make sure that there are no such jumps. All jumps in displacements across steps are ignored
Degree of freedom 4 is not active in this model and can not be restrained
Degree of freedom 5 is not active in this model and can not be restrained
Degree of freedom 6 is not active in this model and can not be restrained
Can you guys help me out? Thx before.
errors:
warnings:
RE: Errors about degree of freedom 11
Sounds familiar... are you using elements that can handle temperature? "Normal" structural elements can't I think.
/S
I think i'm not doing something about temperature.
"Normal" what?
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
By normal I mean a structural element, default settings in CAE.
In the video, the guy makes a Dynamic Explicit step (no temperature).
Your error, "Degree of freedom 11 and at least one of degrees of freedom 1 thru 6 must be active in the model for *dynamic temp-disp." leads me to believe that you have a different step type from what you want.
Hope it works out. :)
