swing check valve used with air operated double diaphragm pump
We are planning on utilizing a few pneumatic diaphragm pumps which will be discharging into a pressurized drain system. We currently have swing type check valves in the discharge of the pumps (as all lines entering the pressurized drain system have check valves).
Is there any good reason why we shouldn't use swing check valves in the discharge line? Like because its in reciprocating service and may wear excessively?
RE: swing check valve used with air operated double diaphragm pump
I wouldn't worry about the wear, but a cwing check can cause hammers if backflow closes it too quick. It isnt clear the process contitions for your service or criticality. Process PD pump piping deserves some attention because of pulsation, premature pump or relief system failures, etc.
With respect to backflow, most diaghram pumps have internal ball or lift check valves essentual to their method of operation.
Good luch,
Sshep
A discharge pulsation dampener can also further help to smoothen out the flow pulsations with this pump.
