Femap with Nei Nastran rivet forces
Hi all.
Can you aerospace types (or others) remind me how you typically extract shear flows for sizing skin to frame member connections? I have not modeled discrete fasteners, but just used glued contact in my FEA. What is the usual method with "older" FE approaches, i.e. merged shell elements, etc?
tg
tg
RE: Femap with Nei Nastran rivet forces
I have done the same many times - however, do you take the total shear over all the elements in a line and divide by total length (giving average shear flow) or is there another approach?
tg
but summing different element contributions is reasonable for ultimate static design, or you might consider the peak load applied to a representative number of fasteners.
Is there a standard or guide that helps define "representative number of fasteners"?
tg
if you've got a lot of skin panel shear, and are splicing the skin panel, how many rivets would fit within the element ?
you could average over like a frame pitch.
if there's one shear spike, does it look reasonable to smear over three rivets ?
