Help with furnaces
Help with furnaces
Help with furnaces
Do you know about frequent failures in an industrial furnace, in particular those located at Z-neck and SQE?
Also, could you suggest a detailed book regarding furnaces operations and maintenance?
RE: Help with furnaces
Your chances of getting good replies is going to be helped if you provide more information about the type of furance and the specifics of that furnance.
Millisecond furnace with induced-draft fan, operating at around 800-870 ℃ and -0.5 mbar.
