API 5L SPEC ... P-NUMBERS AND GROUP NUMBERS
thread292-115971: ASME SECTION IX Welding Procedure Qualification
In asme BPVC section IX you found, NONMANDATORY APPENDIX D "P‐NUMBER LISTING", define de P-numbers and Group Number for Materials API 5L SPEC ...for example API 5L X52 GRADES IS P-1 AND G-1...
I have doubts if you should have impact test for the WPS specification..
RE: API 5L SPEC ... P-NUMBERS AND GROUP NUMBERS
Why?
