A656 Grade 60 and 70
Hi folks,
We manufactured penstock pipes made of A656-12 Gr 60 Type 7. They have flaring (by mechanical deformation) at the ends for assembly and been delivered to the customer on spec but after a while the very tip (bell)part of the penstock was sinked back in and went out of tolerance (shrunk 1-3 mm in diameter). Usually we use A572 Gr 50/60/65 for penstock and never had this issue. I am wondering if anyone has a clue on this?
I checked the A656-13: apparently S, Mn and N content has been revised from A656-12. Not sure this might be a smoking gun!
Appreciate if you can share your ideas/experiences!
RE: A656 Grade 60 and 70
