Typical small building foundation in Maryland
I am a structural engineer in Texas. Normally a foundation for a small building (15' x 50') would be a monolithic slab with a thickness of 6 inches and grade beams around the perimeter that are 12" wide by 18-24" deep. I have a project in Maryland where the frost line is shown as 29". If someone from the Maryland area is reading this could you tell me if a monolithic slab is typical for this type of construction or is the slab poured over a pre-poured foundation or some other type of construction?
RE: Typical small building foundation in Maryland
15'x50' is a weird aspect ratio. Is this agricultural or a wash bay? I'd round that 29" to 30".
"It is imperative Cunth doesn't get his hands on those codes."
The 29" was not the beam depth but the frost line shown in the specifications. My plan was to use a 6" slab with 12" x 36" beams turned down at the perimeter and 12" x 24" beams under the 4 timbers mentioned above. I also plan to specify a couple of contraction joints by cutting the slab about 1" deep along the short dimension and cutting every other rebar.
Any comments you have would be appreciated.
