WELD DESIGN IN PRESSURE VESSELS AND SUPPORTS
I need help with the design of joint for welding in Vessels using the ASME VIII div 1
My questions are:
In what part of the ASME code Can I find about type of joint, root size and groove size?
For the welding in structural supports like legs, lugs, skirts, the design could be using a strucutral code like AISC? or what recomendations do you give me for the welding design in this components?
Thanks in advance
RE: WELD DESIGN IN PRESSURE VESSELS AND SUPPORTS
ASME VIII provides many joint design figures. You need the help of a consultant. You obviously have no experience in vessel design or construction.
