Elevated Tanks
Elevated Tanks
Hi, what are the main parameters that structural engineers require in designing foundations for elevated tanks? Also, assuming that it can be a pillar or multi-column tank. I expect that overturning and therefore uplift resistance may one of the controlling foundation requirements. The tank is most likely to be supported on shallow foundations with gravel soils as the bearing layer at GL -2 to 3 meters.
RE: Elevated Tanks
Mike McCann, PE, SE (WA)
RE: Elevated Tanks
RE: Elevated Tanks
RE: Elevated Tanks
Buggar, to address sensitive soils against cyclic loadings, we do not allow the 1/3 increase of allowable bearing pressure for short-term loading.
Thanks again !!
RE: Elevated Tanks
Thaidavid
RE: Elevated Tanks
In that case, note that the AWWA specifications have some requirements for overturn criteria, seismic loading, wind loading, etc., that are different from ASCE 7.
