Journal: Change font for label on parent
I'm trying to create a journal that changes all fonts in the drawing to Arial (among other things).
So far everything changes except "label on parent". I can't figure out how to change the font for those. If anyone could help me find a code that selects all the label on parents in the drawing and then change their font to Arial that would be much appreciated. I'm running NX8.5 and this is my code so far:
Thank you!
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module set_dim_text_to_arial
Dim theSession As Session = Session.GetSession()
Dim theUfSession As UFSession = UFSession.GetUFSession
Dim workPart As Part = theSession.Parts.Work
Sub Main()
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "change dim text to Arial")
'Load Drafting Standards
Dim loadDraftingStandardBuilder1 As Preferences.LoadDraftingStandardBuilder
loadDraftingStandardBuilder1 = workPart.Preferences.DraftingPreference.CreateLoadDraftingStandardBuilder()
loadDraftingStandardBuilder1.WelcomeMode = False
loadDraftingStandardBuilder1.Level = Preferences.LoadDraftingStandardBuilder.LoadLevel.Site
loadDraftingStandardBuilder1.Name = "FMC_KBG"
Dim nXObject1 As NXObject
nXObject1 = loadDraftingStandardBuilder1.Commit()
loadDraftingStandardBuilder1.Destroy()
'Version up drafting objects
workPart.Drafting.VersionUpAllDraftingObjects()
'Declare Font type
Dim fntArial As Integer = workPart.Fonts.AddFont("Arial", FontCollection.Type.Standard)
'Declare Aspect Ratio
Dim ratio As String = 1
'Change GD&T Settings
For Each tempGdts As Annotations.Gdt In workPart.Gdts
Dim symbolPreferences1 As Annotations.SymbolPreferences
symbolPreferences1 = tempGdts.GetSymbolPreferences()
Dim lineAndArrowPreferences1 As Annotations.LineAndArrowPreferences
lineAndArrowPreferences1 = tempGdts.GetLineAndArrowPreferences()
Dim letteringPreferences1 As Annotations.LetteringPreferences
letteringPreferences1 = tempGdts.GetLetteringPreferences()
Dim generalText1 As Annotations.Lettering
generalText1.Size = 3.5
generalText1.CharacterSpaceFactor = 0.0
generalText1.AspectRatio = ratio
generalText1.LineSpaceFactor = 1.0
generalText1.Cfw.Color = 37
generalText1.Cfw.Font = fntArial
generalText1.Cfw.Width = Annotations.LineWidth.Thin
generalText1.Italic = False
letteringPreferences1.SetGeneralText(generalText1)
tempGdts.SetLetteringPreferences(letteringPreferences1)
letteringPreferences1.Dispose()
lineAndArrowPreferences1.Dispose()
symbolPreferences1.SetWeldSpaceFactor(2.0)
symbolPreferences1.SetWeldSymbolSizeFactor(1.0)
Dim weldSymbolCfw1 As Annotations.LineCfw = New Annotations.LineCfw(37, DisplayableObject.ObjectFont.Solid, Annotations.LineWidth.Thin)
symbolPreferences1.SetWeldSymbolCfw(weldSymbolCfw1)
Dim surfaceFinishCfw1 As Annotations.LineCfw = New Annotations.LineCfw(37, DisplayableObject.ObjectFont.Solid, Annotations.LineWidth.Thin)
symbolPreferences1.SetSurfaceFinishCfw(surfaceFinishCfw1)
symbolPreferences1.DraftingSurfaceFinishStandard = Annotations.SurfaceFinishStandard.Iso2002
symbolPreferences1.WeldSymbolStandard = Annotations.WeldStandard.Iso
tempGdts.SetSymbolPreferences(symbolPreferences1)
symbolPreferences1.Dispose()
tempGdts.LeaderOrientation = Annotations.LeaderOrientation.FromLeft
Dim nErrs1 As Integer
Next
'Change Note Settings
For Each tempNote As Annotations.Note In workPart.Notes
lineAndArrowPreferences1 = tempNote.GetLineAndArrowPreferences()
letteringPreferences1 = tempNote.GetLetteringPreferences()
tempNote.SetLetteringPreferences(letteringPreferences1)
Next
'Change Label Settings
For Each tempLabel As Annotations.Label In workPart.Labels
lineAndArrowPreferences1 = tempLabel.GetLineAndArrowPreferences()
letteringPreferences1 = tempLabel.GetLetteringPreferences()
tempLabel.SetLetteringPreferences(letteringPreferences1)
Next
'Change Weld Symbol Settings
For Each tempWeldSymbol As Annotations.Weld In workPart.Annotations.Welds
lineAndArrowPreferences1 = tempWeldSymbol.GetLineAndArrowPreferences()
letteringPreferences1 = tempWeldSymbol.GetLetteringPreferences()
tempWeldSymbol.SetLetteringPreferences(letteringPreferences1)
Next
'Change IDSymbol Settings
For Each tempIDSymbol As Annotations.IdSymbol In workPart.Annotations.IdSymbols
lineAndArrowPreferences1 = tempIDSymbol.GetLineAndArrowPreferences()
letteringPreferences1 = tempIDSymbol.GetLetteringPreferences()
tempIDSymbol.SetLetteringPreferences(letteringPreferences1)
Next
'Change font in tables
'Change Dimension settings
Dim numBad As Integer = 0
For Each tempDim As Annotations.Dimension In workPart.Dimensions
letteringPreferences1 = tempDim.GetLetteringPreferences()
'The next six lines changes the DistanceBetweenSymbolAndDimensionText
Dim dimensionPreferences1 As Annotations.DimensionPreferences = tempDim.GetDimensionPreferences()
Dim diameterRadiusPreferences1 As Annotations.DiameterRadiusPreferences = dimensionPreferences1.GetDiameterRadiusPreferences()
diameterRadiusPreferences1.DistanceBetweenSymbolAndDimensionText = 0.2
dimensionPreferences1.SetDiameterRadiusPreferences(diameterRadiusPreferences1)
diameterRadiusPreferences1.Dispose()
tempDim.SetDimensionPreferences(dimensionPreferences1)
Dim dimensionText1 As Annotations.Lettering = letteringPreferences1.GetDimensionText
Dim appendedText1 As Annotations.Lettering = letteringPreferences1.GetAppendedText
Dim toleranceText1 As Annotations.Lettering = letteringPreferences1.GetToleranceText
Dim mainText() As String
Dim dualText() As String
tempDim.GetDimensionText(mainText, dualText)
If dimensionText1.Size <> 0.01 Then
numBad += 1
dimensionText1.Cfw.Font = fntArial
dimensionText1.Size = 3.5
dimensionText1.AspectRatio = ratio
dimensionText1.Cfw.Width = Annotations.LineWidth.Thin
letteringPreferences1.SetDimensionText(dimensionText1)
End If
If appendedText1.Size <> 0.01 Then
numBad += 1
appendedText1.Cfw.Font = fntArial
appendedText1.Size = 3.5
appendedText1.Cfw.Width = Annotations.LineWidth.Thin
letteringPreferences1.SetAppendedText(appendedText1)
End If
If toleranceText1.Size <> 0.01 Then
numBad += 1
toleranceText1.Cfw.Font = fntArial
toleranceText1.Size = 3.5
toleranceText1.Cfw.Width = Annotations.LineWidth.Thin
letteringPreferences1.SetToleranceText(toleranceText1)
End If
tempDim.SetLetteringPreferences(letteringPreferences1)
Next
'Change fonts in tabular notes
If IsNothing(theSession.Parts.Work) Then
'active part required
Return
End If
Dim lw As ListingWindow = theSession.ListingWindow
lw.Open()
Dim myTabularNoteTags As New List(Of Tag)
If FindTabularNotes(myTabularNoteTags) = 0 Then
'no tabular notes to process
Return
End If
For Each tableNote As Tag In myTabularNoteTags
Dim numRows As Integer
theUfSession.Tabnot.AskNmRows(tableNote, numRows)
Dim numCols As Integer
theUfSession.Tabnot.AskNmColumns(tableNote, numCols)
Dim tableOrigin(2) As Double
Dim tableSectionTag As Tag
theUfSession.Tabnot.AskNthSection(tableNote, 0, tableSectionTag)
For i As Integer = 0 To numRows - 1
Dim rowTag As Tag
theUfSession.Tabnot.AskNthRow(tableNote, i, rowTag)
For j As Integer = 0 To numCols - 1
Dim colTag As Tag
theUfSession.Tabnot.AskNthColumn(tableNote, j, colTag)
Dim cellTag As Tag
theUfSession.Tabnot.AskCellAtRowCol(rowTag, colTag, cellTag)
'get the current cell preferences
Dim theCellPrefs As UFTabnot.CellPrefs
theUfSession.Tabnot.AskCellPrefs(cellTag, theCellPrefs)
'change the font preference setting
theCellPrefs.text_font = fntArial
'apply the new settings to the cell
theUfSession.Tabnot.SetCellPrefs(cellTag, theCellPrefs)
Next
Next
Next
lw.Close()
theSession.SetUndoMarkName(markId1, "Load Drafting Standard Dialog")
End Sub
Function FindTabularNotes(ByRef theTabNotes As List(Of Tag)) As Integer
Dim tmpTabNote As NXOpen.Tag = NXOpen.Tag.Null
Dim type As Integer
Dim subtype As Integer
Do
theUfSession.Obj.CycleObjsInPart(workPart.Tag, UFConstants.UF_tabular_note_type, tmpTabNote)
If tmpTabNote = NXOpen.Tag.Null Then
Continue Do
End If
If tmpTabNote <> NXOpen.Tag.Null Then
theUfSession.Obj.AskTypeAndSubtype(tmpTabNote, type, subtype)
If subtype = UFConstants.UF_tabular_note_subtype Then
theTabNotes.Add(tmpTabNote)
End If
End If
Loop Until tmpTabNote = NXOpen.Tag.Null
Return theTabNotes.Count
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
'----Other unload options-------
'Unloads the image immediately after execution within NX
'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
'Unloads the image explicitly, via an unload dialog
'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly
End Function
End Module
Thank you!
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Sub Main()
'Declare Font type
Next
Next
Next
Next
Next
numBad += 1
End If
numBad += 1
End If
numBad += 1
End If
Next
Return
End If
lw.Open()
Return
End If
Dim rowTag As Tag
Dim colTag As Tag
Dim cellTag As Tag
Next
Next
Next
lw.Close()
End Sub
Dim type As Integer
Do
Continue Do
End If
End If
End If
End Function
End Function
End Module
RE: Journal: Change font for label on parent
I have managed to stitch together another script that fixes the font for label on parents. So this script and the one I posted earlier works fine separately and gets the job done. But I don't know how to combine the two, as I don't understand how a function works:) Any tips on how to combine this script with the one I posted above?
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
' NX Font Update
' Journal created by Alto on 20-05-2015
Module NXJournal
Dim theUfSession As UFSession = UFSession.GetUFSession()
Sub Main()
'Update Label Font for all the Labels not letter size factor
Dim NULL_TAG As NXOpen.Tag = NXOpen.Tag.Null
Dim obj As NXOpen.Tag = NULL_TAG
Do
obj = ask_next_drf_entity(obj)
If obj = NULL_TAG Then
GoTo end1
End If
' Check whether returned Tag is UF_draft_label_subtype
Dim type As Integer = Nothing
Dim subtype As Integer = Nothing
theUfSession.Obj.AskTypeAndSubtype(obj, type, subtype)
Dim nxobj As NXObject = Utilities.NXObjectManager.Get(obj)
If nxobj.GetType().ToString() <> "NXOpen.Annotations.Label" Then
Continue Do
ElseIf nxobj.GetType().ToString() <> "NXOpen.Annotations.Labelonparent" Then
Dim Label1 As Annotations.Label = nxobj
Dim letteringPreferences7 As Annotations.LetteringPreferences
letteringPreferences7 = Label1.GetLetteringPreferences()
Dim generalText5 As Annotations.Lettering
generalText5.Size = 3.5
generalText5.CharacterSpaceFactor = 0.0
generalText5.AspectRatio = 1.0
generalText5.LineSpaceFactor = 1.0
generalText5.Cfw.Color = 37
generalText5.Cfw.Font = fntArial
generalText5.Cfw.Width = Annotations.LineWidth.Thin
letteringPreferences7.SetGeneralText(generalText5)
Label1.SetLetteringPreferences(letteringPreferences7)
letteringPreferences7.Dispose()
Label1.RedisplayObject()
Continue Do
Else
End If
Loop Until obj = NULL_TAG
End1:
End Sub
Public Function ask_next_drf_entity(ByRef obj As NXOpen.Tag) As NXOpen.Tag
Dim part As NXOpen.Tag = workPart.Tag
theUfSession.Obj.CycleObjsInPart(part, UFConstants.UF_drafting_entity_type, obj)
Return obj
End Function
End Function
End Module
I was able to combine the two scripts after all:) Seems to be working as I want now:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Sub Main()
'Declare Font type
Next
Next
Next
Next
Next
numBad += 1
End If
numBad += 1
End If
numBad += 1
End If
Next
Return
End If
lw.Open()
Return
End If
Dim rowTag As Tag
Dim colTag As Tag
Dim cellTag As Tag
Next
Next
Next
lw.Close()
Do
GoTo end1
End If
Continue Do
Continue Do
Else
End If
End1:
End Sub
Return obj
End Function
Dim type As Integer
Do
Continue Do
End If
End If
End If
End Function
End Function
End Module
