Norsok R-001, Nozzle loads
Dear All,
Norsok R-001 specified the minimum nozzle loads on the equipment nozzle, but it is not clear the type of these loads (Sustain, Operation, Occasional). I received nozzle loads (different cases) from our piping team defined as per DNV-RP-D101. For instance I have sustain load case (Weight + Design Pressure + Spring) and Operation case (Design conditions+Wind+Motion displacement). I'm not sure if I have to check both these cases against the minimum ones as per R-001.
Please kindly let me know your opinion
Thanks in advance
BR,
