Datum Point Ratio
Datum Point Ratio
Datum Point Ratio
I'm trying to create a Datum Point - Offset Ratio - End of Curve - (a straight line length of 50 mm, offset ratio 0.01) and it does not work - point is created at the end of the line. I've checked config.pro and Model Properties - all right. Then I did the same thing, but with Offset Real 0.5 mm (ie, ratio 0.5/50 = 0.01), and everything works (true less than this size again nothing happens). Please help. Thank U.
RE: Datum Point Ratio
All that comes to mind is that the part accuracy is too low.
Thanks. What it should be?
