Wiring schemaitc example .dwg file.
I was wondering if someone can help me by giving a .dwg file of a wiring schematic as an example where I can build off of and use as a starting place. Also if someone could tell me the formal name/type of schematic/diagram that is pictured in the attached file.
RE: Wiring schemaitc example .dwg file.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
If you don't know something you ask a question, which is what I was doing. The real danger is doing without knowing and NOT asking questions.
xnuke
