NX clone assembly/part to next revision of a released part in Teamcenter
I would also like to clone an assembly, in Teamcenter Nx,the next revision (new, WIP) of a released file.
I am working in Teamcenter and have WAVE linked assemblies that are study files that I would like to clone back to original production parts so that I don't have to spend hours relinking everything.
I select the assembly, select Numbering tab, select User Number. I (dry run) walk through the parts and NX asks for the number and the revision for each part but the operation fails. The error is "part file already exists". The revision level that I want to create does not exist. The Item and a released item revision do exist. (Revision 001 is released and i want to clone to revision 002).
I thought I was able to do this in NX7.5 and before. Perhaps I am mistaken. Or is this a Teamcenter configuration issue?
Thanks.
