Macro interaction -> AUTOCAD2015 and Access2010
Hi everyone. I have a problem with a macro that I am trying to build.
The macro purpose is connect AUTOCAD 2015 to an Access 2010 database.
I need to create a button in AutoCAD environment, which automatically archives technical drawings. Every single draw will has a unique sequential code created by an existing Access macro
and recoded into database "CODIFICA.accdb".
I would like to take advantage of an existing macro in Access (called: "CODIFICA DISEGNI"). That macro creates sequential Codes for the drawing and other secondary parameters.
I am still blocked on the initial code, What I was able to put together And this:
Sub codice_nuovo_disegno_prova ()
A Dim Target As
Set A = CreateObject ("Access.Application")
A.Visible = False
A.OpenCurrentDatabase ("C: \ Users \ xxxxxxx \ Desktop \ CODIFICA.accdb")
A.DoCmd.RunMacro "CODIFICA DISEGNI"
A.DoCmd.SelectObject acForm, "PROTOCOLLO DISEGNI", True
A.DoCmd.Runcommand (PulsanteCreaNuovoCodice)
End Sub
On this few line of row code I made a mistake or forgot to activate some library because the Access database open, the macro run, the form activate but it gives me error:
"Run-time in 2501: the RunCommand Action Has Been Locked".
In my intentions, my AUTOCAD macro will:
- open the Access databese "CODIFICA.accdb"
- runs the macro "CODIFICA DISEGNI"
- activate the form "PROTOCOLLO DISEGNI"
- simulate button clicking "PulsanteCreaNuovoCodice" - this button allow to create the new sequential code (You can choose also to create more than one code) and record it on the database
- save the AUTOCAD draw on as the new sequential code on a folder
note: "PROTOCOLLO DISEGNI" is a form of the macro "CODIFICA DISEGNI" and "PulsanteCreaNuovoCodice" is a button on the form "PROTOCOLLO DISEGNI"
Currently everything is done manually with the two software AUTOCAD and ACCESS.
ps. If I remove the line of code "A.DoCmd.Runcommand (PulsanteCreaNuovoCodice)" the macro runs without errors, of course stops the opening of the macro and the form
I thank in advance who will help me
