Lifting Padeye on I-Beam
Hi All,
I am designing a structure with a final load of 25 tonnes. While I have designed lifting padeyes in the past where padeyes have been slotted through tubes (circular, square, and rectangular). This case is the padeye is to be welded on a I-Beam, but instead of just welding it with a full penetration weld on the upper flange, I want the padeye to be slotted to give it extra strength in the joint (welding on top and bottom flange).
1. Can you please advise what will be a better way to slot a padeye to the structure? There are 4 lifting padeyes in each corner.
2. Also, what effect will the welding joint have on the thin web of the I-beam when the 25 tonne structure is lifted?
3. Any other option where we can have redundancy in the padeye joint?
Attached picture for reference.
HD
RE: Lifting Padeye on I-Beam
I would just stick with welding the padeye to the top flange, over the web. If that doesn't work by the numbers somehow, pick a beam with a thicker web. The slotted detail will be expensive and I'm not sure that it adds anything meaningful to your capacity.
A bolted connection would likely give you the most redundancy
To increase the weld joint length to the top flange of the I-beam, buy a rated padeye instead of slotting the I-beam and machining the complex insert and fillet welding (?) all around the insert.
A purchased forged padeye will have an extended base that gives you more weld area to the top I-beam flange.
why slot the flange ? why not "just" cut it off ? I mean, the I-beam shouldn't be doing much bending there ?
