Data from Exel
Data from Exel
Hi everybody,
I am wondering, is there any way to extrude data from Exel file and to use it in my lisp routine??
Please help
Zmei
Please help
Zmei
RE: Data from Exel
There is some facilites lets you extract data from Excel and use it in AutoCAD. I will check it for you and if I find the way, I will let you know about it.
Farzad
RE: Data from Exel
I dont know if this will be of any use, but you can generate scripts from excel spreadsheets using scriptsheets.com scriptwriter(and its free).
Peter
RE: Data from Exel
RE: Data from Exel
;; Point A
;; A scroll from the Wizard's Lab.
;; Bill Kramer 2002
;; Interface with Excel Worksheet
;; Global Variables
;; xL - Object reference to EXCEL instance
;; myXLWbs - Object reference to EXCEL work books
;; myXLWb1 - Object reference to Work book #1
;; myXLShs - Object reference to Sheets in Work book
;; myXLSh1 - Object reference to Sheet 1
;; myXLNms - Object reference to list of named cells
(vl-load-com)
;; Open link to EXCEL spreadsheet, use existing
;; instance of EXCEL if one exists otherwise
;; load EXCEL and then open the file supplied
;; as the variable xLFile.
(defun Link_2_Excel (xLFile)
(setq xL ;Attempt to open existing or create new Excel instance
(vlax-get-or-create-object "Excel.Application"))
(if xL ;;success?
(progn
(if (and xLFile (findfile xLFile)) ;;Was a file name supplied?
(progn
;; We have the application object, now we need to tunnel
;; down into a work book.
(if (null xl-open) ;;Check to see if type library defined
;;It is not, import the type library for EXCEL
(vlax-import-type-library
:tlb-filename "C:/Program Files/Microsoft Office/Office/Excel8.olb"
:methods-prefix "xL-"
:properties-prefix "xLp-"
:constants-prefix "xLc-"))
;; Now dig into the EXCEL object
(setq myXLWbs (vlax-get xL "Workbooks") ;workbooks
myXLWb1 (xl-open myXLWbs xLFile) ;open a workbook
myXLShs (vlax-get myXLWb1 "Sheets") ;worksheets
myXLSh1 (xlp-get-item myXLShs "Sheet1") ;worksheet number 1
myXLNms (vlax-get myXLWb1 "Names") ;get reserve names
xL ;;return the object reference
;; Given a name that represents a variable in the EXCEL spreadsheet,
;; send the value in VAL to EXCEL.
;; Note that the linkage to EXCEL MUST be determined before calling
;; this function!
(defun Update_Variable (Varname ;;Variable name
Val ;;Value to write to spreadsheet
TMP ;;Named object reference
Rng) ;;Range in spreadsheet (location)
(setq TMP
(vl-catch-all-apply ;;Catch errors if they happen
'vla-item ;;Get the name from the names collection
(list
myXLNMS ;;collection of names from Link_2_Excel
VarName)))
(if (and ;;No errors and item found?
(not (vl-catch-all-error-p TMP))
(setq Loc1 (vlax-get TMP "Value")))
(progn ;;yes, get the range of the named item and update the value
(setq Rng (xlp-get-range Sh1 Loc1))
(xlp-put-value Rng Val)
;; Close the EXCEL spread sheet after saving it.
(defun Close_XL (SaveFileName)
(xl-saveas myXLSh1 SaveFileName)
(xl-close myXLWb1)
