plus/plus tolerances
Search came up pretty empty, maybe because I'ma asking the question badly.
A coworker ProE user claims Wildfire4 won't accept +/+ tolerances.
Like +33/+20 in an ISO F6fit as shown here -
http://www.wisetool.com/fit.htm.
If true, is there a workaround?
thanks
Dan T
RE: plus/plus tolerances
I tested it on Creo 2.0 and you can actually just select Plus-Minus tolerance mode and enter a positive # in the lower tolerance. I'm not sure how this is treated in tolerance analysis, etc, but I'll bet it translates correctly.
http://xternal.me
I've done it many times, you have to put a minus sign in the negative tolerance box. A double negative is positive in this case.
