HYSYS – Simulation of a distillation column with defined cutpoints for sidedraw
Dear all,
I am trying to find the best way to simulate and design a distillation column with a defined cuts for a sidedraw. The sidedraw will be the mainproduct in this operation.
Example:
Assay Boilingrange: 150°C to 350°C
Sidedraw with CUT: 200-300°C
Which type of Subflowsheet and respective specifications should be used for the simulation?
I solved the Simulation using: “distillation column subflowsheet” with the specs: "temperature on the draw tray" to 200°C @ vap frac 1 and 300°C @ vap frac 0.
But…this way seems to be too time consuming and I think there might be an easier way as defined cuts for sidedraws should be used often enough in refinery-engineering.
What's your poinion?
Andre
RE: HYSYS – Simulation of a distillation column with defined cutpoints for sidedraw
On Pro II- Simsci, it is possible to set the side draw specification based on ASTM D86 IBP or EBP - you havent said what reference std is relevant to this 200-300degC side draw.
The same specification variable should be available on the simulator you are using ?
Thanks George,
I defined two Specs (in HYSYS called 'cutpoint') to receive a defined draw:
Spec1:
Stage 13
Type: D86
Temp: 200°C
Phase: Liq
Spec2:
Stage 13
Type: D86
Temp: 300°C
Phase: Vap
Let's say stage 13 ist my stage for the sidedraw.
For solving the simulation, I have to vary the drawstage and the cutpoint-specs manually - this way seems to be quite time-consuming.
Andre
The D86 spec seems to be incomplete : D86 at what % by volume does this temp refer to?
Wny are you specifying both the vapor and liquid D86 points (and at what % as mentioned by George)?
How many specs do you have to provide and what are you providing in addition to these two?
@all:
see my specs in the attached pdf.
@TD2K:
Wny are you specifying both the vapor and liquid D86 points --> warong post by myself...see pdf attached
My question: is there an easier way to run the simulation than using these three specs?
Andre
I'm not seeing a PDF attached. Post a sketch of your system and some information on the feed and products you want.
In general terms, I prefer to initially set up a distillation just on flows, that gets the model converged usually fairly easily. I can then look at the streams and either start changing the flows to get properties to match what I want or change the spec then to a D86 or some other specification. Do one stream at a time, don't try to put D86 specs on all three streams and hit the "solve" button.
Initial estimates can really help. Spend some time with pen and a piece of paper so you have an idea of what the general splits should be. If you are setting up a crude tower, you should be able to look at the feed stream and get reasonable estimates for the naphtha, kero, diesel, etc streams from the feed assay.
Usually the D86 95% v/v temp is used on the main column side draw to vary reboil, and the D86 5% v/v temp is specified on the side stripper to vary steam rate.
