CATIA V6 Plane repitition
Hi!
I'm looking for a script or macro which allows me to create planes on all points and a curve i have made.
I have a excel file with xyz coordinates which I import into Catia (V6 GSD) creating a geometrical set called "GeometryFromExcel". This geometrical set contains all points and creates a spline through all these points.
I want to create planes on every single point regardless of its name (example: Point.1 or point.50 shouldnt matter). Using the "normal to curve" function of planes.
The amount of points may vary.
Hope you guys can help out!
Cheers
RE: CATIA V6 Plane repitition
do you import excel points into V6 with a script?
Eric N.
I Do. I use the script which is already in Catia. I believe its called : GSD_PointSplineLoftfromExcel.xls
why don't you modify it to create the plane?
Eric N.
I would not know how..
So basically i want to have a set of planes all offset from the XY plane which can be made using a txt file or excel file.
I've tried to record my own macro but i do not know how to get it to loop...
As written above, I do have a way to input points and a line using a excel table.. just not the planes yet.
CODE -->
Sub CATMain()
Dim editor1 As Editor
Set editor1 = CATIA.ActiveEditor
Dim part1 As Part
Set part1 = editor1.ActiveObject
Dim hybridShapeFactory1 As HybridShapeFactory
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Item("GeometryFromExcel")
Dim hybridShapes1 As HybridShapes
Set hybridShapes1 = hybridBody1.HybridShapes
Dim hybridShapeSpline1 As HybridShapeSpline
Set hybridShapeSpline1 = hybridShapes1.Item("Spline.1")
Dim reference1 As Reference
Set reference1 = part1.CreateReferenceFromObject(hybridShapeSpline1)
Dim hybridShapePointCoord1 As HybridShapePointCoord
Set hybridShapePointCoord1 = hybridShapes1.Item("Point.1")
Dim reference2 As Reference
Set reference2 = part1.CreateReferenceFromObject(hybridShapePointCoord1)
Dim hybridShapePlaneNormal1 As HybridShapePlaneNormal
Set hybridShapePlaneNormal1 = hybridShapeFactory1.AddNewPlaneNormal(reference1, reference2)
hybridBody1.AppendHybridShape hybridShapePlaneNormal1
part1.InWorkObject = hybridShapePlaneNormal1
part1.Update
Dim settingControllers1 As SettingControllers
Set settingControllers1 = CATIA.SettingControllers
Dim settingRepository1 As SettingRepository
Set settingRepository1 = settingControllers1.Item("VPMEditorDisplay")
boolean1 = settingRepository1.GetAttr("Mask_LockEditability")
End Sub
the loop should be around
you can loop all element in hybridShapes1 and test if you have a point
CODE --> catvba
for each oShape in hybridShapes1
 if typename(oShape) = "Point" then
Set hybridShapePointCoord1 = oShape
next
that should take all points in that geometrical set
Eric N.
I now have below code. It doesnt give an error but doesnt do anything either. I'm sorry for being such a newbie at scripting..
CODE -->
Sub CATMain()
Dim part1 As Part
For Each oShape In hybridShapes1
If TypeName(oShape) = "Point" Then
part1.Update
End If
Next
End Sub
insert
CODE -->
MsgBox (TypeName(oShape))
before
CODE -->
this will help you find the type of point
once you have it replace
CODE -->
with the proper Type.
do this with a small number of points in your file.
Eric N.
