Duct Fabrication - SMACNA DCS - Transverse Joint - Standing S T12
With reference to the subject title, I did not understand a passage in the SMACNA Duct Construction Standard Metal and Flexible, Second Edition, page 1.63:
Joint [...] T-12, STANDING S: When using S on all four sides, fasten the slip to the duct [...] at 12" (305 mm) maximum intervals.
I thought the Standing-S slip/drive has the same length as the duct side it is joining so I did not understand what was meant by maximum intervals. So if the duct side, to be joined with a Standing-S, is longer than 305mm I have to make more than one cleat?
Can someone please explain?
RE: Duct Fabrication - SMACNA DCS - Transverse Joint - Standing S T12
S bar on all 4 sides is normally used where the duct has to break away such as at a fire damper through a fire wall.
If you use S joints on all four sides for anything else , it has to be treated as a slip joint, with fasteners screwed or riveted through it to retain the duct. Otherwise the method is S bar on two sides opposite and drive lock on the other two sides.
B.E.
You are judged not by what you know, but by what you can do.
Thanks berkshire but the phrase maximum intervals is referring to what exactly- the side length?
As far as I know , it means exactly what it says , I interpret this as the maximum spacing between fasteners, so if you have a 48" wide duct you would need at least 4 fasteners in that side.
B.E.
Yes I get it. If fasteners are not used and all four sides are using S then it will be a slip-joint and it can be dislocated. The intervals are like the ones shown in Fig 1-11 of the same standard. Thank you berkshire.
