Parametric Note on memebers of Assembly
Hello Friends,
I have an assembly and i want to attach a parametric note on each member. There is a common parameters (say Description)in all the parts. When i place the note in assembly using "&description:sesion_id". But Pro/e Shows it as text, not its value. I don't want to disply these notes in part(only in assembly).
Any suggestions.
Nikhil Gothankar
RE: Parametric Note on memebers of Assembly
Make sure that the parametric note is a text line by itself, and not part of a longer text line.
Such as:
{0:The value}{1:&description:6}
Is not the same as:
{0:The value &description:6}
Steve
http://www.3dlogix.com
I am just entering &ref_no:2 (where ref_no is a part parameter)
In Relation, If i enter ref_no:2 in Evaluate form it, gives correct output.
Nikhil Gothankar
