Book or standard with general corrosion data
I'm looking for any official book or documentation that lists corrosion rates of various metals with various services.
For example Carbon Steel in saltwater, ammonia, sulphuric acid.
Are there any standards with such data or are these only obtained from in-service measurements?
RE: Book or standard with general corrosion data
There is the ASM Handbooks, the Compass Corrosion Guides, the data published by Outokumpu, the Material Selector series from MTI, and those are ones that I can see from my desk.
Identify specific service environments and then look for references.
You also need some test books, because in order to use the data you need to understand what is causing the corrosion (the underlying mechanism) so that you don't misapply the information.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
