API 650 Tank Retension Time
Is anyone familiar with recommended API 650 retention times? I am looking for the retention time for a 400 BBL API 650 oil storage tank. The oil is API 35 degree oil.
I cannot find anywhere in API 650 that specifies a retention time.
Thank you in advance.
RE: API 650 Tank Retension Time
I suspect this is a process related question and API 650 is not going to address for you. However, some more explanation what you want will get you a better answer.
Inspections according to API 653 need to be done by an authorized inspector, of course all described in given code.
