VBScript Existing Component Loop Problems
Hello all,
I made the script to make Existing Component with Do ... Loop.
This can make just first time and after can't make it and pop up the errors.
Here is my script. Could you tell me where it is wrong?
CODE --> VBSCript
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
Set product1 = productDocument1.Product
Set products1 = product1.Products
Do
Dim arrayOfVariantOfBSTR1(0)
arrayOfVariantOfBSTR1(0) = "C:\tmp\Part1.CATPart"
products1.AddComponentsFromFiles arrayOfVariantOfBSTR1, "All"
AskMsgBox = MsgBox("Whould you like to do once more?", vbYesNo, "Question")
Loop Until AskMsgBox = vbNo
End Sub
RE: VBScript Existing Component Loop Problems
try:
CODE --> vba
do while AskMsgBox = vbNo
loop
Eric N.
Thank you for your reply.
I tried to do with your script. I'm sorry but anything doesn't happen, even the Msgbox doesn't work.
So I modified yours to below script. But also this doesn't work with pop up the error.
Only 1st time can make it and after it doesn't work.
Could you tell me why it doesn't work..?
CODE --> VBScript
Do until AskMsgBox = vbNo
  Dim arrayOfVariantOfBSTR1(0) ' -----> Here is error line
  arrayOfVariantOfBSTR1(0) = "C:\Temp\Part1.CATPart"
Loop
CODE --> VBScript
Do while AskMsgBox = vbYes
Loop
ok sorry for that. my code works fine for me:
CODE --> CATVBA
Do While AskMsgBox  <> vbNo
    arrayOfVariantOfBSTR1(0) = "C:\temp\Part1.CATPart"
Loop
ok now with VBScript:
I change your code to
CODE --> CATScript
Sub CATMain()
	Loop
End Sub
and it works. you see the added files only after you reply No.
Eric N.
Thanks a lot for your fast answer!!
Perfectly this works what I want. Now I can work!! ㅜ.ㅜ
I hope everything are going well with you!!
