weld for horizontal beam to vertical col (concrete)
For a connection i have, its a 90 deg corner, so I have a small plate called out to make the welds...this allows a bit for erection tolerances. DO you guys use plates, or just a round bar and weld top and bottom?
RE: weld for horizontal beam to vertical col (concrete)
