FLANGE ISOLATING GASKET KITS
Hello everyone,
We hired a manufacturer to build a produced water treatment skid, containing a Vertical Water Skimmer tank and a Flotation Cell tank. The skid will be operating for a temporary plant for a 5 year span located near the tropical rain forest. Both tanks are of Stainless Steel and all the piping is of Carbon Steel.
Issue: SS gasket and zinc stud bolts w/o washers were used at the connection between the CS piping and the tanks SS flange. Instead of using a Flange Isolation Gasket kit they followed their standards b/c they never received the specifications.
Question: Have you guys seen this before? Is it acceptable? It is being suggested to leave it that way since it is only for relatively short term use, but I am not sure if corrosion will be a factor in a very humid environment.
Edit: I just came to realize that being that this is a on a CS skid, isolation gaskets become useless because everything is in contact because of the skid. Any comments will be much welcomed.
Thank you for anyone that responds.
RE: FLANGE ISOLATING GASKET KITS
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
