Bending moment for shell element in etabs: Urgent please help me
I would like to know if the moment gets transferred from walls to the frames in etabs, as it does transfer the loads from slabs to the beams. So i would like to know if the Bending moment in shell elements (walls) will be transferred to the Columns(frames. reply me soon please.
Vignesh
RE: Bending moment for shell element in etabs: Urgent please help me
This is not clear at all. How will the moment carried by the wall be transfered to the columns ?
This is not the correct load path.
yes that's what i mean its wrong. I am done with modelling and analysis. How do i determine bending moment for walls (shell element) in etabs ?
If u need to read the integral values acting on ur walls, u have to give a pier name for each segment of wall. Then u can display the different actions avting on the wall (beding shear axial torsion)
