Is 100% bearing contact always required?
In checking P/A +/- M/S for eccentric loading on a rectangular footing: is it left up to engineering judgment and a client decision to determine if slightly less than 100% bearing contact pressure is acceptable, OR is this never acceptable? This is in regards to a 30' tall vertical vessel on a 9'x9' footing that has 80% bearing contact when it has worst-case horizontal wind loads. But the footing would have to be increased up to like a 14x14' footing to get 100% bearing contact with these wind loads. (As these calculations assume, overburden and concrete weight are disregarded. But when those are factored in, the overturning stability is more than sufficient. So my scenario is that the vessel is safe against falling over, but my question is in regards to the soil bearing contact pressures.) I'll be having the standard design review on this by another engineer, but I wanted to get some input from engineers on this board. Thank you.
RE: Is 100% bearing contact always required?
Mike McCann, PE, SE (WA)
