Critical path
Critical path
I am a little bit confused on this: After pressure balance by design, how could there be a critical path (since all paths have the same pressure loss now)? I am designing a local exhaust system and each path starts from the terminal to the exhaust fan.
RE: Critical path
All paths will have equal pressuredrop - no matter what. Problem is, this is not the flow you want. So you use dampers to reduce the flow while keeping pressure the same in all runs.
RE: Critical path
