Determination of gas volume coming from an orifice
So I am trying to determine the volume of a gas that has been put through a filter so I can do some calculations.
I randomly have the formula Density (lb/Ft3)* Volume (Ft3/min) = 2.5985
But I am not sure where I got this from. The only things I know are what type of gas it is, the PSI that gas was flown through the filter, how long it was allowed to flow, and the diameter of the outlet. I could probably make an assumption about temperature if necessary. I am not looking for an exact number but being able to get something in the ball park of what it really is would be very useful.
RE: Determination of gas volume coming from an orifice
That's all.
How or whether this applies to your filter - if you don't know how are we supposed to.
In the complete absence of any other information this is an impossible question to answer.
What else would I need to solve it? It seems like if you know what pressure something is flowing at, how big the hole it is flowing through is, and how long it is flowing that you should be able to come up with a pretty good guess of the volume.
