H beam structure for a cargo lift.
I have been doing cargo lifts which has a simple construction of 02 nos H beam like 40 cm apart in between a small platform resting on a L brackets moving up and down . The dimensions of the platform is 1.5 mts X .9 cm , the height of H beam is 9 mts . The question is how much load can my platform take? What should I need to do if i want to increase the size of platform?
RE: H beam structure for a cargo lift.
reading your post, how can anyone help with the info provided?
Dimensions do not make sense. Consider providing a sketch.
If you are looking for engineering services - perhaps hire someone who can help you?
mine is a small time venture , i just want to sure how safe am i ? how much load can my structure take ? how many supports should be there to make the structure safe?
Spend a few $ and hire a professional engineer to help you do what you want to do. Then you will know for sure and the solution will be custom to your situation.
ZCP
www.phoenix-engineer.com
Doesn't matter if you are a small time venture. Eng-Tips isn't here for free engineering services - to verify sizes for members in real projects. That is what we all are in business for.
Hire an engineer if you need that kind of help.
