Find time step where maximum occurs
I'm working on a transient thermal analysis in workbench. If possible I'd like to automatically find the timestep where the maximum temperature occurs and then select this time step for some post processing. Is there an easy way or a command to do this/
I'm working on a snippet that will find out how many time steps there are, then use a DO loop to go through the results and write the time step number and the maximum temperature to a table. And then find the maximum temperature and the corresponding load step. But there might be a built in command that can do this for me.
Kind regards
George
