Adding Acadentity to a selectionset
I am creating an entity in VBA and want to add the same to a selection set. How do i do it.
Dim newline as Acadentity
Set newLine = ThisDrawing.ModelSpace.AddLine(startpoint, EndPoint)
' now i want to add this to a selection set
Additems is used to add a selection set to another so how can i add this item to a selection set.
Could someone help me in this regard.
RE: Adding Acadentity to a selectionset
Seems to me that you should have posted this in your CAD software's forum.
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
