bolt tightening
bolt tightening
bolt tightening
I want to tight the bolts of for example one 20 inch flange.
I know the bolt size and bolt material.
I have calculated the yielding strenght for bolt material.
Now what should I do?
RE: bolt tightening
  • Go to www.asme.org
  • Look for ASME PCC-1
  • Purchase a copy
  • Start reading ASME PCC-1
RE: bolt tightening
Find out what gasket you are using and then ask the manufacturer of the gasket what bolt material and torque you should use. Or as mentioned above, get PCC-1, read it so you can figure it out.
RE: bolt tightening
Knowing torque values is one, understanding them is a second.
