Does battery self discharge when connected
I am an electric engineer, and I read about battery self discharge phenomenon. I was wondering whether a battery self discharge rate is the same when it is unconnected (i.e. in storage) and connected (i.e. when it is plugged into a device and being discharged "normally"). In other words, when I calculate battery life time for a product, should I take add the rated self discharge of a battery to the general current calculations or not? And also-is the answer similar to all types of battery?
Thank you in advance.
Udi
Udi
RE: Does battery self discharge when connected
Your self-discharge current is usually very low level, and would likely alter the lifetime calculation by less than 1%
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
I've also designed things that draw less current than the battery's self discharge rate making the battery the major consumer.
If the device has a real power switch disconnecting the battery entirely then the self discharge is only a function of the battery chemistry and the ambient.
Keith Cress
My question is really: does the battery self discharge at the same rate when it is being drawn from, or does the self discharge only happens when it is disconnected?
It's the same since it is really a corrosion/chemical aging process that still occurs during usage.
Keith Cress
Think of the self-discharge as a parasitic load in parallel with the external load.
TTFN
Hadoo
Head designer at www.lianinno.com
