fan selection for duct work
To select a fan with the right static pressure, should I just use the pressure loss of the critical path or add up pressure losses from all the duct sections?
RE: fan selection for duct work
Do not forget to add the critical path of your return duct work, grilles, diffuses, and any other items outside the air handling unit if it is a single fan unit.
There are other descriptions likely in SMACNA, this is one that comes to hand readily.
