Determining Final Yield Strength & Elongation from Sheet to Tube - HSLA Steel
Is there a rule or thumb, or an approximate calculation that can be performed to determine the strength increase (and elongation decrease) which occurs when roll forming a flat sheet into a circular (tubular) profile, given the thickness, outside diameter and flat sheet mechanical properties for an HSLA steel?
Jeff
Jeff
RE: Determining Final Yield Strength & Elongation from Sheet to Tube - HSLA Steel
You will need to know the strain hardening coefficient (n) and strength coefficient (K) for HSLA steel.
Jeff
Jeff
It should only take a few tests for you to build your own correlation.
I was hoping to be able to use tensile properties/results from the flat sheet to predict the tube properties when I don't have a tube to test. Ultimately I want to be able to use different tube thicknesses and diameters in a design and I wouldn't be able to test for every combination.
Jeff
You can assume a K, or test and find one, finding one that is reliable for your specific steel could be difficult.
