ANALYZE HORIZONTAL LEG OF STEEL ANGLE
I’ve never been taught to analyze the allowable capacity of the horizontal leg of a steel angle supporting either a point load or continuous load.
How do I determine the acceptable angle thickness?
Do I need a gusset?
In past years, I’ve been considering the horizontal leg to be a cantilevered beam with a fixed supported end. Am I performing a correct analysis?
RE: ANALYZE HORIZONTAL LEG OF STEEL ANGLE
I think you are performing a correct analysis but you must decide on the effective width of leg in the case of a point load. You might need a gusset but not if the point load is small. You should not need gussets for a continuous load. For strength calculations of a point load, you could perform a Yield Line analysis. Alternatively, you could adopt a reasonable assumption as to leg width based on experience.
BA
Here are some good articles that deal with this and advise on the appropriate yield line pattern:
Link
Link
Thank you both for your input.
KootK - thank you for the resource(s), however, the second "Link" only flashes briefly and I am unable to use it. Clicking on it several consecutive times allowed me to see that it is from SteelJoist.org, but, I cannot clearly decipher the rest of the address. Will you please provide the address? Thank you very much!
http://steeljoist.org/LiteratureRetrieve.aspx?ID=3...
FWIW: I'm using Chrome.
