Can Wood Brace a Steel Beam?
Is it acceptable to consider a steel beam to be laterally braced by wood trusses, purlins, joists or other repetitive wood members at 24" o/c or less?
Top / compression flange bearing?
Bottom flange bearing?
Thank you.
Thank you.
RE: Can Wood Brace a Steel Beam?
BA
