Hydraulic Pressure Regulator / Reducer Supplier
I am looking for a hydraulic pressure regulator / reducer which can handle 1,500 L/min of a water glycol fluid taking the pressure stored within a bank of accumulators @ 4,000 Psi down to a supply pressure of 1,500 Psi.
Any ideas who would be able to supply not only a valve of this size but one which will be able to run on a glycol fluid?
RE: Hydraulic Pressure Regulator / Reducer Supplier
Suggestion, but you will have to ask directly to get a special version for your capacity, or have to use parallells. Company is known for ability to quote and supply special versions in reasonable time. Better commercially availablle versions in Europe if you can go down to P1 250 bar (3626 psi.) US standard flanges should be no problem on machined valves.
http://mankenberg.de/en/20/prgb:1/product:pressure...
