Hydraulic Pressure Regulator / Reducer Supplier
I am looking for a hydraulic pressure regulator / reducer which can handle 1,500 L/min of a water glycol fluid taking the pressure stored within a bank of accumulators @ 4,000 Psi down to a supply pressure of 1,500 Psi.
Any ideas who would be able to supply not only a valve of this size but one which will be able to run on a glycol fluid?
RE: Hydraulic Pressure Regulator / Reducer Supplier
