CATPart or CATProduct Copy & Paste Question
Hallo, all
I think this script is very simple but it doesn't work as what I want.
I recoreded the macro to copy and paste a cataprt or catproduct.
And I modified a little bit like below script.
To copy "Part1" in "Product1" works very well.
But it doesn't work in "Product2".
I uploaded the picture of tree to attatched file.
I want to copy and paste a CATPart or CATProduct in every product.
Could you check my script?!
Link
CODE --> VBSCript
Language="VBSCRIPT"
Sub CATMain()
Dim Inputobject(0)
Dim Selection(1)
Set productDocument1 = CATIA.ActiveDocument
Set selection1 = productDocument1.Selection
selection1.Clear
Set product1 = productDocument1.Product
Set products1 = product1.Products
MsgBox "Please, Select a Product for linked part."
Set Selection(0) = CATIA.ActiveDocument.Selection
Selection(0).Clear
Inputobject(0) = "Product"
Status = Selection(0).SelectElement2(Inputobject, "Select a Product", True)
SelObj1 = Selection(0).Item(1).Value.Name
'Set product2 = products1.Item("Product1.1")
Set product2 = products1.Item(SelObj1)
Set products2 = product2.Products
MsgBox "Please, Select a Part to copy."
Set Selection(1) = CATIA.ActiveDocument.Selection
Selection(1).Clear
Status = Selection(1).SelectElement2(Inputobject, "Select a Product", True)
SelObj2 = Selection(1).Item(1).Value.Name
'Set product3 = products2.Item("Part1.3")
Set product3 = products2.Item(SelObj2)
selection1.Add product3
selection1.Copy
Set selection2 = productDocument1.Selection
selection2.Clear
selection2.Add product2
selection2.Paste
End Sub
RE: CATPart or CATProduct Copy & Paste Question
strange code...
why selection(0) and selection(1) ???
Also I would replace:
by:
set TargetProduct = Selection(0).Item(1).Value
Same way I'll use :
set sourcePart = Selection(0).Item(1).Value
and finally
with selection
.clear
.add sourcePart
.copy
end with
Final code:
CODE --> CATVBA
Sub CATMain()
    Dim Inputobject(0)
    Dim oSel 'As Selection
    Set oSel = productDocument1.Selection
    oSel.Clear
    MsgBox "Please, Select a target product to receive Part."
    oSel.Clear
    Status = oSel.SelectElement2(Inputobject, "Select a Product", True)
    Set targetProduct = oSel.Item(1).Value
    oSel.Clear
    Set sourcePart = oSel.Item(1).Value
    With oSel
        .Clear
        .Add sourcePart
        .Copy
        .Clear
        .Add targetProduct
        .Paste
        .Clear
    End With
End Sub
Eric N.
Thank you so much, itsmyjob!!
Your answer saved me today!! That is absolutly what I want!!
Fist I thought I need two selections. One is "Target Product", the other is "Part to copy".
This is reason why I use selection(1) before knowing "wiht" method..
I haven't seen the "with" method before..
I think you must be prodigy! winky smile Thank you!!
