Optimization with eigenvalue issue
hey all,
running an optimization task to a part, one of the design responses in 'eigenvalue from modal analysis'
after starting the job with all parameters set i get an error message.
the monitor says i need to change the SUBSTEP value from all to one eigenvalue.
my question is where is this option to change the SUBSTEP, as i have had no luck finding the command to do so
Pic of issue is attached
Thanks in advance for any help
