Punching shear and direct shear in pile cap design
As far as I know, when I design a pile cap, I need to check the direct shear in two orthogonal directions, and then I need to check the punching shear under the concentrated load or support. Then I have a question, should the provided shear reinforcement be the sum of the three components (direct shear x + direct shear y + punching shear)? Some said that after I have checked the punching shear and provide punching shear reinforcement, I no longer need to check for the direct shear. Is that correct?
Thanks very much for help.
RE: Punching shear and direct shear in pile cap design
I agree that both direct shear and punching shear should be evaluated in all cases.
